[IMTS Preview] New Line of Configurable Machining Centers from Mitsui Seiki
Mitsui Seiki will introduce its line of large capacity, heavy-duty, and configurable machining centers to North America at IMTS 2010. The new HU100 series is the first range of configurable machining centers aimed at a variety of manufacturing industries interested in versatile equipment for heavier applications. The concept of configurable machines has been a part of Mitsui Seiki philosophy for many years, but only recently has the concept been standardized for the marketplace. Configurable machines are those that are based on a set of standard modular components that can be arranged to suit specific customers’ needs easily and affordably.
Mitsui Seiki’s design approach allows users can choose axis travels from 1,300 mm to 2,500 mm, 4, 5, or 6 axes of continuous motion with a choice of a rotary table, trunnion table, or table on table. There’s also a variety of spindle choices, including fixed spindles from 6000 rpm (50 hp, 2000 ft./lbs. torque) for heavy milling up to 25,000 rpm for high speed applications. Tilt or swivel spindle choices are available from 6000 rpm (800 ft./lbs. torque) for heavy milling up to 12,000 rpm for high speed machining. Mitsui Seiki also offers quill type spindles for precision boring with shorter tools. Of course, Mitsui Seiki applications engineers will assist customers in selecting the optimum component choices to meet their needs and objectives now and in the future.
The HU100 series is ideal for larger aerospace and power generation parts with a work zone capacity of up to 2,500 mm dia. x 2,000 mm height. The machines accommodate weights from 4400 lbs. (2,000 kg) to 17,500 lbs. (8,000 kg). These machines can be equipped with simple pallet changers to fully integrated FMS systems for work and raw material handling. Likewise, tool-handling systems range from on-board magazines to central systems for more than 2500 tools.
Launched earlier this year, the HU100 line is already one of Mitsui Seiki most popular products, and has been sold to industries as diverse as aerospace, refrigeration compressor, mold & die, heavy equipment, and energy. All of these industries have fundamental common requirements: machine rigidity /stiffness and high accuracy.
As with all Mitsui Seiki’s machine tools, high accuracy and ultra rigidity come from the builder’s attention to the basic structure, 3D FEM Design, hand scraping of all castings for geometry and frequency tuning, plus hardened and ground steel box ways. All critical components for the machines are designed, manufactured, and quality controlled in-house at one of the world’s most advanced machine tool factories.
