Workholding Jaws Increase Pull-Down Effect
DILLON MANUFACTURING’s hard chuck jaws have diamond-shaped serrations that increase the pull-down effect, which reduces part slippage and push back from using a bar feeder. Serrations on the gripping surfaces are ideal for cast parts, scaly parts, or parts with imperfections. They are manufactured of 8620 steel and case-hardened with precision ground locating surfaces, then black oxide coated for corrosion resistance.
The hard jaws are available in one-step or two-step sets and are reversible for OD or ID chucking. One set covers a wide clamping range. Dillon hard jaws are available in standard sizes from stock and in different mounting configurations including serrated, T&G, Acme, and square serrated key types to fit all brands of chucks.
Dillon chuck jaws are very versatile with multiple radiuses for both inside and outside clamping making then ideal for any size run. Dillon also offers special or modified hard jaws with industry-best turnaround time, which saves time and money by reducing down time. Learn more at www.dillonmfg.com
