Injection-mold-machine robots
Designed for top loading/unloading injection-molding machines, the KS Series of shelf-mounted 6-axis robots has a low profile for platen-mounted robots, which reduces required ceiling heights for injection-molding machines for payload up to 1,200 ton. Three models, with 70.87-in. (1,800-mm) vertical reaches, are available for payloads up to 132-lb (60-kg). The KS Series is also suitable for die-casting machines and machine tools for part loading/unloading, palletizing, deburring, and part making.
Kuka Robotics Corp.
Clinton Township. Mich.
kukarobotics.com
