The Gap Between Buying a Machine and Running It Profitably
Key Highlights
- Increasing CNC utilization and focusing on niche markets can boost shop profitability.
- Automation and standardized tooling reduce set-up times and improve overall efficiency, leading to higher margins.
- Proper training and constant monitoring of CNC machines help prevent downtime and optimize production output.
- Understanding the full costs of ownership and accurate job quoting are essential to maintaining healthy profit margins.
- Implementing these strategies ensures that CNC investments translate into tangible business growth and success.
CNC machines are a cornerstone of modern machine shop operations. Programmable computer numerical control (CNC) allows shops to control the movement of cutting, drilling, milling, turning, or shaping tools automatically, expediting production and maximizing productivity using CNC mills, lathes, routers, and plasma cutters.
Consequently, CNC machining has increased shops’ efficiency and capabilities significantly, improving output and product variability. However, many machining experts have identified a verifiable profitability gap between buying CNC equipment and using it to make a profit in a shop environment.
Often, this gap is linked to shop operators’ assumption that CNC machines are some sort of “magic box” that can eliminate almost all human input. In reality, CNC machines need to be supported by sound human strategy that will bridge the profitability gap. Below, we’ll explain why this gap exists and give you some helpful strategies for closing it.
Factors behind the profitability gap
Utilization. CNC machines are undoubtedly revolutionary production systems, but what separates machine usage and the operator’s profitability is how often and how well the machines are put to use. Critical technologies like CNC routers can cut manufacturing time exponentially, but the operator’s net profits depend on how often the system is used. There’s a great difference between a shop that uses 20 hours per week of CNC power versus one using 50 hours per week.
More time and effort dedicated to CNC machining will result in higher profitability, and a shop’s ability to optimize CNC operating time depends on a variety of factors.
Cost of ownership. There’s no doubt that CNC machining is a booming industrial segment: data showing shipments of cutting tools rising steadily from 2025 to 2026 indicates growing demand for manufactured parts, and thus increasing rates of manufacturing activity. But while manufacturing technology is selling well, machine shops are often not fully aware of the full cost of ownership associated with a CNC machine. Additional costs associated with CNC machines include tooling, maintenance, electricity, and spare parts. Each of these may reduce profitability from a CNC machine, especially one that’s older or outdated.
Operator and programmer skills. Alongside ownership costs and utilization issues, profit gaps can come into play when a shop lacks an properly skilled workforce to handle CNC technology. CNC machine operators need to know not only how to program machines and operate them safely, but also how to troubleshoot errors and repair malfunctions. It’s important to note that workforces with only limited CNC machine experience may actually add to manufacturing and production time, wiping out the purpose for investing in CNC machinery.
Inaccurate pricing and quoting. If machine shop owners and managers lack a full understanding of CNC machines and how they work, their misunderstanding may lead to issues with job pricing and quotes. Shops that fail to adequately account for the overhead and production costs associated with CNC machines may present clients with inaccurate quotes, resulting in unprofitable returns on their work. A machine shop that’s ineffective at calculating production costs can blow its margins on materials and labor, leaving little return on investment.
Set-up, changeover, and maintenance. Another factor shaping the profitability gap is the time needed to set up, change over, and maintain CNC machines. Extensive set-up and programming times add length to jobs before they even start, and this can be exacerbated if workers need help in programming CNC machines due to lack of skill.
Changing systems for live tools like CNC routers make transitions between different jobs easier and faster, but not every shop has them - and those that lack this capability will spend a lot of time transitioning between projects.
Of course CNC machines also break down, like any other mechanical device. This adds even more time to jobs, as workers have to expend effort maintaining and fixing the machines.
How to close the profitability gap?
Find a niche market. Regardless of the type of machine shop, finding a niche market is one of the best ways to maximize CNC output and bridge the profit gap. Certain niches may offer better returns on projects through higher pricing and quotes, increasing revenue. Furthermore, focusing on a particular niche may eliminate a great deal of changeover time if a shop’s machines are generally focused on a single product vertical.
Automate operations and workflows. Adding automation at various stages of the workflow is one of the best ways to achieve profitability on CNC machine capital investments. Many small businesses and shops have turned to automation for quick quoting, cost control, and increased efficiency. Automating elements of your workflows - like loading and unloading - can transform a workspace entirely, allowing for a considerable increase in “lights-out” manufacturing, ramping up production without additional overhead.
Standardize tooling. Keeping your tooling standardized across jobs is a vital part of reducing the periodic downtime that results from changeover procedures. When your CNC machines aren’t calibrated to retool swiftly, or when they need to frequently alternate between vastly-different projects, you waste critical time making necessary changes and programming alterations.
By optimizing your tooling procedures and limiting tedious changeover, you help whittle away at the lost revenue that results from changeover downtime. This also will increase overall efficiency, and when paired with automation this can narrow the profitability gap even further.
Prioritize training. Obviously, having a well-trained workforce will contribute to productivity and efficiency. If your employees aren’t able to effectively learn the ins and outs of CNC machining, you have little chance of effectively profiting from your investment.
Whether it involves bringing on consultants to oversee employee training or appointing supervisors from your workforce to head up a technology-focused arm of the company, training will keep your employees up to speed and adaptable to technological advances, ensuring that there are no complications or time wasted due to training delays.
Implement constant monitoring. Because CNC machines are capable of breaking down like any other type of machinery, constant monitoring is necessary to keep productivity and revenue high. Investing in CNC monitoring software will help to avoid the cost of extra staff for work that you can largely perform yourself.
CNC monitoring software can distinguish between the actual and perceived uptime of your machines, explaining why they have idle periods and what you can do to mitigate them. Effective monitoring can often lead shops to experience up to 25% gains in efficiency, showcasing how important constant surveillance is to a thriving business.
Final thoughts on profiting from CNC equipment
The demand for various additional shop services is increasing daily, and with that increase comes the need for shops to stay ahead of the technological game. Investing in CNC machinery will advance a shop’s technological resources, but requires additional effort by the operators to maximize the value of those CNC machines.
The strategies outlined here will help eliminate the gap between buying CNC equipment and making it a profitable part of your business, ensuring that your growth is stable and minimizing further overhead costs.
Jess Muehlfeld
Marketing Supervisor
Jess Muehlfeld is the Marketing Supervisor at Laguna Tools, bringing a performance focused, content-first approach to woodworking, furniture and cabinet making, signage, CNC routing, and metalworking sectors.
Related
Worker operating CNC milling machine.
