Compact Turning Center with a Y-Axis
The Lynx 2600SY was designed to provide maximum flexibility and versatility for job shops that want to handle a wider range of projects without stepping up in size to a PUMA Series boxway machine.
A new feature on the Lynx 2600SY is the latest controller from FANUC, the 0i-TF Plus, which is available with an optional iHMI user interface, specifically designed by FANUC for ease of use. The 0i-TF Plus features 3D part views that will offer more detail, which are easily viewable on the 15-in. touch-screen (previously 10 in.) The control is equipped with the Doosan EZ guide conversational programming feature but doesn't take away the traditional G-code programming language. Learn more at www.doosanmachinetools.com
