The JTEKT Group, which is a joint venture that combines Toyoda Machinery USA (www.toyoda.com) and Koyo Machinery USA (www.koyomachinery.com), will showcase several innovative machining and grinding systems. As Toyoda’s largest ...
The JTEKT Group, which is a joint venture that combines Toyoda Machinery USA (www.toyoda.com) and Koyo Machinery USA (www.koyomachinery.com), will showcase several innovative machining and grinding systems. As Toyoda’s largest horizontal machining center, the FH1250SX features a new column and hightorque spindle for rapid cutting (more than 50 percent higher than typical boxway machines) without compromising rigidity. Koyo is highlighting its fully automated KC-500 cam journal grinder and a fully automated KVD-300W VVT surface grinder.
