A decade ago machining operations were being lured into the cloud, as control software and data sets were elevated out of the earthly plane and into the ether. It was an evolution that had begun a decade earlier, with MTConnect. More than just mastering how their milling, turning, grinding, or other CNC machines worked, manufacturers were evolving their understanding of data and its accessibility as a resource in processing.
In course, on-premises data hosting became an option, and more and more activity - all the consequential activity - was happening “out there.” And the need to make all that data accessible and useful shifted manufacturers’ perspectives away from the shop floors and into the unlimited dimension where the data lives.
When IMTS 2024 opened, the presence of Nvidia, Google, AWS, and more as exhibitors made perfect sense. These businesses were where they were in demand.
The activities on machine shop floors has never stopped being defined by precision and repeatability. That’s the effect of automation. But today machine shops also need data predictability and adaptability, and that’s the work of intelligence … manufacturing intelligence. It’s a connected, data-driven approach that makes CNC machines active participants in enterprise-wide decision making rather than isolated production assets.
Visitors to IMTS 2026 will recognize that this shift is possible because of advances in industrial automation, controls integration, artificial intelligence, edge computing, and connected services. These are the manufacturing technologies that optimize machining, improve quality, and maximize equipment utilization.
Integrated AI for machining
Probably the most significant development is the integration of AI into machining operations. Rather than relying on predefined machining parameters, AI-powered systems can analyze real-time sensor data to recommend adjustments to feeds, speeds, and cutting conditions. These adaptive capabilities help reduce tool wear, minimize scrap, and improve overall process consistency.
Digital twins have also become production tools, as manufacturers simulate machining operations, validate process changes, and compare expected versus actual machine performance before implementing adjustments on the shop floor.
And automation is expanding beyond individual CNC machines. Modern machine work cells combine robotics, automated pallet systems, tool presetting, and in-process inspection to support extended unattended operation. While lights-out manufacturing remains an important objective, the greater value lies in enabling skilled personnel to oversee multiple machines and focus on process optimization instead of repetitive manual tasks.
A truly transformative change involves controls integration. Historically, CNC controllers operated independently from other factory systems, limiting visibility into production performance. Today, manufacturers are connecting CNC equipment with programmable logic controllers (PLCs), supervisory control and data acquisition (SCADA) platforms, manufacturing execution systems (MES), enterprise resource planning (ERP) software, quality management systems, and computerized maintenance management systems (CMMS). This convergence of operational (OT) and information technology (IT) allows production schedules, machine status, quality data, maintenance records, and inventory information to flow seamlessly throughout the organization.
Open communication and connected services
Open communication standards are accelerating this transition. Technologies such as OPC UA, MQTT, MTConnect, and industrial Ethernet enable equipment from different manufacturers to communicate using standardized protocols, reducing integration complexity and supporting mixed-vendor manufacturing environments. As a result, manufacturers can build scalable digital infrastructures without being constrained by proprietary interfaces.
Connected services are also becoming an essential function for CNC machining operations. Machine builders and automation suppliers have standardized cloud-based platforms that provide remote machine monitoring, predictive maintenance, remote diagnostics, software updates, tool life analytics, and production benchmarking. Instead of reacting to equipment failures after they occur, manufacturers can identify abnormal machine behavior early and schedule maintenance before unplanned downtime impacts production.
This evolution also changes how manufacturers approach industrial data. Most machine shops already generate vast amounts of machine information, but collecting data is no longer the primary challenge. The real opportunity lies in contextualizing that data by connecting machining parameters with tooling information, inspection results, maintenance history, production schedules, and energy consumption. Edge computing further enhances this capability by processing time-sensitive information locally while synchronizing analytics with cloud platforms for enterprise-wide visibility.
Risks of connectivity
As connectivity expands, cybersecurity has become a critical design consideration. Secure remote access, network segmentation, zero-trust architectures, strong authentication, and compliance with standards such as ISA/IEC 62443 are increasingly necessary to protect connected manufacturing environments. The same connectivity that enables predictive maintenance and remote service also requires manufacturers to safeguard operational data and production systems against evolving cyber threats.
The manufacturing workforce is evolving alongside these technologies. Automation is redefining the roles for machinists. Engineers and operators today must be able to interpret production analytics, optimize machining processes, manage robotic systems, and coordinate digital manufacturing technologies. New career opportunities are emerging in automation engineering, controls integration, manufacturing data analysis, and industrial AI implementation.
The transition from CNC machine automation to manufacturing intelligence represents more than a technological upgrade - it is a fundamental shift in manufacturing strategy. Intelligent machining environments combine automation, connectivity, analytics, and AI to create production systems that continuously learn, adapt, and improve.
Manufacturers that invest in interoperable controls, connected services, secure industrial networks, and data-driven decision making are positioned to improve productivity, reduce downtime, and respond more quickly to changing customer demands.
