Drills for Micromachining
March 25, 2008
The MiquDrill line from Mikron Tool (www.mikron.com) is designed for small and medium-batch quantities and minimal holes per workpiece. Center drills, available in various diameters from 0.5 mm to 6 mm, center for small drilling ...
Center drills, available in various diameters from 0.5 mm to 6 mm, center for small drilling diameters starting at 0.1 mm (0.003937 in.), while simultaneously performing a 90-degree or 120-degree chamfer.
The short MiquDrill 200 drills holes of approx. 2 or 3 times its diameter. As a pilot drill, it guarantees the precise execution with the MiquDrill 210, for example, and achieves the precision needed in deeper hole drillings. Both drills are designed for micromachining and are available uncoated in diameters down to 0.1 mm and coated from 0.3 mm. The short-drill product line is offered in 0.01-mm increments to 1.5-mm diameter, while the universal MiquDrill 210 product line is available in increments from 0.01 mm to 2 mm, and subsequently in every 0.05 mm to a maximum diameter of 3 mm.
Latest from Cutting Tools
Jergens Inc.
Cornelius20 | Dreamstime
April 28, 2025
Mariusz Pietranek
