AI-assisted CAM may seem to be the perfect answer to the machining labor shortage. It can recognize features, recommend strategies, generate toolpaths, and reduce programming time. If software can do more of the routine work, a machine shop may reasonably ask why it should hire so many junior programmers or machinists.
But if every shop were to ask the question at the same time, it would present a real threat to the future of manufacturing.
There is a lack of programmers and machinists. The latest Stanford Digital Economy Lab employment update found that the shortfall for workers ages 22 to 25 in occupations that are highly exposed artificial intelligence widened from 15% in the July 2025 data vintage to 19% by June 2026. The deterioration is occurring mainly through a reduced rate for hiring of young workers.
Machining already faces the opposite problem: too little experienced talent. Recently, American Machinist noted that AI-assisted CAM does not eliminate the need for skilled CNC programmers and machinists because successful machining still depends on practical experience, judgment, cutting tools, materials, machine capabilities, and production requirements.
Those skills do not appear spontaneously when someone is promoted into a senior role. They are built one set-up, one bad finish, one broken tool, one chatter problem, and one unexpected material response at a time.
Beginner tasks vs. beginner jobs
That is why shops should distinguish between automating beginner tasks and eliminating beginner jobs.
Let AI generate the first toolpath. Then require the junior programmer to explain the choice of cutting strategy, challenge feeds and speeds, identify where tool deflection might matter, and compare the simulation with what happens on the machine.
Let AI suggest a sequence. Then have the newer machinist determine whether workholding, thermal growth, chip evacuation, tool access, or tolerance stack-up makes that sequence unrealistic.
Let an AI system surface likely causes of poor surface finish. Then put the employee at the machine with an experienced operator and make the diagnosis physical: sound, vibration, insert wear, coolant, rigidity, material condition, and setup.
This makes the early-career role more technical, not less.
Machine shops have always relied on apprenticeships because machining contains too much tacit knowledge to live entirely in documentation. A veteran operator knows that two nominally identical machines can behave differently. An experienced programmer sees when an aggressive theoretical toolpath will create trouble in a particular fixture. A machinist notices the subtle evidence that a process is drifting before the inspection report confirms it.
AI can help capture that expertise. It cannot replace the process of acquiring it.
Apprenticeship accelerator
Therefore, the best shops should use artificial intelligence as an apprenticeship accelerator. Every time a senior programmer overrides an AI-generated strategy, capture the reason. Every time a machinist changes a set-up because the digital recommendation does not match physical conditions, turn the exception into a teaching case. Every time a junior employee catches a bad recommendation, record the reasoning and review it with the team.
Then track a metric that matters more than programming minutes saved: time to independent competence.
How long does it take a junior programmer to create a reliable process without a senior person correcting major assumptions? How soon can a machinist distinguish a tooling problem from a workholding problem? How quickly can a new employee predict the downstream effect of a seemingly minor setup change?
If AI shortens those timelines, it is helping solve the skills shortage. If it merely reduces junior hiring, it is borrowing against the future workforce.
This matters because automation itself is increasing demand for capable people. American Machinist has reported that machine-tool investment reflects, in part, growing demand for automation amid a persistent shortage of skilled labor. More sophisticated equipment does not make expertise irrelevant. It raises the value of people who can integrate, diagnose, and improve it.
The widening, 15-19% early-career employment gap should push machine shops to act before the apprenticeship pipeline becomes any less reliable.
The goal is not to keep junior employees writing code that a machine could write better. The goal is to use AI adoption at work to expose those young minds to more real machining judgment, more quickly, so the industry produces the experienced people it will still need ten years from now.
