Counter support holds parts
Hirschmann Engineering U.S.A. Inc. has redesigned its H4265 Slid-Able counter support for wire EDMs so that workpieces have two levels on which they can be placed and clamped. The support bottom has a removable 6-mm-thick base and is the same height as the plate that supports the parts. When the base is removed, parts are held at the machine table's zero line. In the center of the support is an elongated slot that allows lateral adjustment of 4.50 in. in the machine's work zone. www.hirschmannusa.com
