Hose Clamps Secure Jaws
July 5, 2006
Ihad to machine the O.D.s and two sides of flanges welded to the ends of long pipes. To hold the parts, I cut special blank soft jaws for a lathe by machining surfaces equal distances from the key on all three jaws as shown in the illustration. After ...
Ihad to machine the O.D.s and two sides of flanges welded to the ends of long pipes. To hold the parts, I cut special blank soft jaws for a lathe by machining surfaces equal distances from the key on all three jaws as shown in the illustration. After installing the jaws, I realized I had to use three hose clamps to cut I.D.s matching the parts. With the jaws tightened against the clamps, I machined the jaws to suit the pipe I.D., loosened the jaws and removed the hose clamps. I chucked the workpieces, mounted a steady rest and machined the flanges.
Niles Bradley
Westerly, R.I.
