Flexible Horizontal Band Saws for Cutting Aluminum
COSEN SAWS with V_Drive are modern solutions for cutting aluminum efficiently. The most popular models include Cosen Saws G320 and C-Series Horizontal band saws, which are able to cut harder denser materials like titanium, Hastelloy, and other nickel-based metals at significantly increased rates. With aluminum, these machines focus on generating high blade speed with the correct combination of horsepower and torque within the gearbox and motor, so that even at high speeds the machine is not overworked and can still provide excellent cuts.
Combined with big tooth blades, the band saws create the right amount of clearance when cutting common types of aluminum, including 6061, 6063, 6070, and more making them the ideal solution for metal fabrication and steel service centers.The G320 features a hydraulic dual column design and a capacity of 12.8x15 inches. It is one of the smartest saws available right now and features Smart NC-100 (SNC-100) technology and V_Drive built in. SNC-100 controls are programmable up to 100 different jobs including quantity and length of cut. The controls automatically compensate for Kerf loss after data input and requires no manual calculation of number of times to index.
For more traditional solutions, Cosen’s Circular Series offers specifics models designed to cut non-ferrous metals, such as aluminum and copper. The saw’s blade runs at an extremely high speed which makes it one of the fastest cutting machines on the market. Cosen’s non-ferrous machines help fulfill customer needs in a precise and efficient manner, resulting in fast cutting, tight tolerance, and a great finish. Cosen Saws Circular Series consists of the CC-100 and CC-150.
When comparing different types of saws, consider that advances in band saw technology have helped expand options for cutting aluminum.
Learn more at www.cosensaws.com
