Versatile Gear Hobbing Machine
AFFOLTER GROUP’s AF160 gear hobbing machine is “designed for high precision manufacturers that need versatility and maximum efficiency,” explained Vincent Affolter, managing director. “With eight axes, a state-of-the-art digital CNC control, a variety of automation solutions and a maximum module of 2 mm, it is ideal for manufacturers in industries such as automotive, aerospace, aircraft, gearbox, medical or robotics.”
The AF160 can process parts with an outside diameter of up to 60 mm and a length of 250 mm. The machining length is between 110 and 180 mm. The eight axes – all of them independent – make the AF160 the most flexible Affolter machine to date.
It can produce straight gears, helical gears, straight bevel gears, face gears, straight or helical crowned gears, worm screws, worm wheels, cylkro gears, and internal gears. Power skiving, the milling of worms and shafts, as well as chamfering are possible, too.
Depending on the application and production processes, manufacturers need automation solutions to facilitate an autonomous operation for 12 to 24 hours. Affolter provides the AF72 universal multi-axes part loading and unloading system, especially designed for the AF160. It features a double gripper system for parallel loading and unloading and offers different methods of feeding based on the volume, product, and application.
The AF160 also can be equipped with the AF54 deburring unit, integrating the deburring process into the gear production. Different clamping systems provide for added versatility. Customizable coolant systems and chip extraction conveyors are available as well.
AF160 technical characteristics:
‐ 8 axis CNC
‐ Max. module: 2.00 m / 12.7 DP
‐ Max. cutting length: 110-180 mm / 4.33-7.08 in.
‐ Max. part diameter: 60 mm / 2.36 in.
‐ Spindle rotation B: 9,000-16,000 rpm
‐ Spindle rotation C-C: 5,000-12,000 rpm
‐ Dimensions LxWxH: 1,500x2,010x2,650mm
‐ Weight: 3’900 kg / 8.598 lb
Learn more at www.affoltergroup.ch
