Why Do Plant Logistics and SCM Projects Under-Deliver?
Key Highlights
- Most failures occur months before go-live, during planning sessions because scope and timelines are not grounded in real plant data.
- Vendor selection often prioritizes features over operational fit, leading to systems that do not support actual workflows.
- Effective communication of plant-specific requirements and dedicated cross-functional leadership are critical.
- Thorough business cases based on actual throughput and equipment data help set realistic expectations and resource allocations.
- Operational success depends on comprehensive training, SOP development, and knowledge transfer, not just system installation.
Most plant logistics and supply chain technology investments do not fail at go-live. They fail months earlier, in a planning session where a vendor hands over a 14-week implementation timeline, and nobody - not the plant manager, not the engineering lead, not the operations director - pushes back on what it will actually take to integrate a new system into a live manufacturing environment. By the time the project is six months in with no end in sight, the damage to production continuity, equipment utilization, and capital budgets is already done.
This is not an edge case. According to Gartner’s Logistics Functional Transformation Survey, 76% of manufacturing logistics technology transformations fail to hit their critical success metrics. McKinsey research adds a sobering corollary: even implementations broadly deemed “successful” still lose approximately 20% of their projected value post-launch. And despite these persistent failure rates, 80% of manufacturing organizations have attempted four or more technology deployments in under five years, chasing plant efficiency and logistics ROI that keeps slipping just out of reach.
For an upper mid-market manufacturer with $200 to 300 million in freight spend, a botched TMS or warehouse management system implementation typically amounts to a multi-million-dollar mistake in hard remediation costs alone - not counting lost production throughput, inbound supply disruptions, delayed ROI, or the cost of equipment sitting idle while integration rework drags on. For large manufacturers, that number scales into the tens of millions.
So, what keeps going wrong? Increasingly, plant engineers and operations managers are recognizing that these failures do not originate during implementation. They are rooted much earlier - in how the project is scoped, how plant-level requirements are translated into software specs, and in how success is defined before a single line of code is written or a single integration is mapped.
The same four failure patterns appear again and again across manufacturing logistics and supply chain technology deployments - and they are preventable, but only if you know to look for them before the project kicks off.
Reason 1: The expectation vs. reality gap
The most common root cause of a troubled implementation is not a bad vendor; it’s a misaligned one. Plant managers and engineers walked into a vendor demo, saw a polished feature set, and signed a contract for capabilities they’ll rarely use and integration complexity they never fully accounted for. Recent industry survey data makes the scale of this concern clear: 27.9% of manufacturing technology decision-makers cite fear of overpaying for capabilities they rarely use, while 26.5% flag underestimating integration complexity as a primary risk. These are not abstract fears. They are the direct downstream consequences of a vendor selection process that prioritized feature breadth over plant-level operational fit.
When the technology meets the reality of day-to-day plant operations - inbound material flows that do not match the system’s default configuration, equipment and ERP interfaces that require custom integration, and production-linked logistics processes the platform was never designed to support - the gap between what was demonstrated in a conference room and what can actually be delivered on the plant floor becomes the defining story of the engagement.
Reason 2: Planning failure, or the 14-week illusion
Vendors are ultimately incentivized to win contracts, which creates a natural bias toward optimistic timelines and simplified scoping assumptions. The result is a persistent and costly illusion: a project scoped at 14 weeks that is actually a 14-month integration effort - one that plays out against live production schedules that cannot be paused - presented with confidence and accepted without adequate technical scrutiny. Industry experience suggests roughly eight out of ten manufacturing technology implementations are significantly underestimated in both cost and effort, because vendors are structurally incentivized to minimize numbers that could threaten the deal.
This failure is compounded by a chronic lack of business case rigor. The industry research found that only 13.1% of manufacturing logistics technology business cases are built using rigorous methodology. The rest are back-of-envelope calculations that are rarely grounded in actual plant throughput data, equipment cycle times, or real integration architecture - and they collapse under the weight of a live production environment.
Reason 3: The design communication gap
Even when technology is the right fit and the plan is reasonably constructed, projects stall in the design phase because plant engineers and operations teams cannot effectively translate their facility-specific requirements into vendor-ready specifications. The software vendor does not understand how inbound dock sequencing, production scheduling, and line-side delivery interact in a real manufacturing plant. The plant team cannot articulate those interdependencies in terms the vendor can configure.
Recent survey data reinforces how widespread this disconnect is. Only 8.2% of organizations report delivering training tailored to specific workflows and roles - plant logistics coordinators, production schedulers, dock supervisors, and maintenance engineers - while over 40% say their systems were designed with role-based intent but ultimately delivered in a generic, off-the-shelf way that does not reflect how the plant actually operates. This gap between intended design and practical usability is a direct reflection of breakdowns in how plant-level requirements are communicated and translated into software configuration.
The result is what practitioners describe as a cycle of repeated requirement rework: the same needs are revisited again and again without resolution, stretching timelines to multiples of their original estimate while time and budget are consumed with little measurable progress.
One client recently described it this way: “You stood up the TMS. Carriers are connected, lanes are configured, the data is flowing. But our production team is still managing inbound deliveries on whiteboards because the system does not reflect how our dock scheduling actually works, and nobody trained us on the exception workflow.” The software was installed. The plant operation was never ready to run on it.
Reason 4: Lack of cross-functional orchestration
A typical TMS or WMS deployment in a manufacturing environment touches inbound material logistics, dock operations, production scheduling interfaces, warehouse management, outbound distribution, customer service, ERP integration, and IT, while simultaneously coordinating the software vendor, systems integrators, ERP middleware providers, and multiple carrier and supplier environments. Without a dedicated orchestrator holding all of these parties to a shared objective - one who understands both the plant floor and the software stack - the project fractures along functional lines.
Survey data highlights just how often this orchestration layer is missing or ineffective. Only 10% of organizations report having a single lead with clear authority driving the implementation, while nearly 49% say leadership was assigned but authority was fragmented across plant operations, IT, logistics, and engineering. An additional 25% relied on vendors or systems integrators as de facto project leads - a structure that routinely produces technology configured for a generic warehouse, not a specific manufacturing environment. In other words, the vast majority of projects operate without a truly empowered central orchestrator.
This is the orchestration gap, and it’s the most structurally misunderstood failure component in manufacturing technology delivery. Every participant - the software vendor, the IT team, the plant operations group, the logistics function - optimizes for their own piece of the puzzle without a shared view of what the plant is actually trying to achieve. Production cost savings get traded away for deployment speed. Automation and integration targets get descoped to make a go-live date. The throughput and efficiency ROI promised in the business case evaporate one compromise at a time.
What a better plan looks like
These four failure patterns share a common thread: they are all front-loaded problems that surface in the back half of the project. The structural decisions that caused them were made months earlier, during planning, during design, during the framing of the business case.
Organizations that avoid these pitfalls invest upstream. That means building business cases with genuine financial rigor before selecting technology - grounded in actual plant throughput data, equipment utilization rates, and real integration architecture. It means pressure-testing vendor timelines against the real complexity of a live manufacturing environment. It means establishing a pre-implementation readiness phase, aligning vendors, IT, plant engineering, and operations leadership to shared program objectives before a single integration is scoped or a single configuration decision is made.
It also means recognizing that systems integration and operational integration are not the same thing. Getting the software installed is the floor, not the ceiling. The manufacturers that realize sustained ROI are the ones that fully operationalize the system - ensuring plant engineers, logistics coordinators, dock supervisors, and production schedulers know how to use it in their daily workflows, that SOPs, throughput KPIs, and inbound freight performance metrics are built around it, and that knowledge transfer at go-live is treated as a plant operations deliverable, not an afterthought.
The potential for a multi-million-dollar mistake in manufacturing logistics technology is almost always made before anyone realizes it’s happening - in a vendor demo, a planning session, or a business case that was never challenged against the realities of a live plant floor. The good news is that none of this is inevitable, but closing the gap requires genuine investment in the planning, plant-specific scoping, and cross-functional governance infrastructure that most manufacturing technology implementations skip entirely.
Brad Forester
Founder and Managing Partner
Brad Forester is the founder and managing partner of JBF Consulting, a logistics strategy advisory and technology integration firm. He brings more than 25 years of leadership experience in transportation strategy, logistics technology, and supply chain transformation. Learn more information at www.jbf-consulting.com.
Related
Empty warehouse shelves.
