High-Penetration Drilling System
Allied Machine & Engineering Corp. (www.alliedmachine.com) will demonstrate its expanded GEN3SYS high penetration drilling system. The increased range for this tool is now 12 mm to 32 mm, with 3-, 5- and 7-times drill depth–todiameter ...
Allied Machine & Engineering Corp. (www.alliedmachine.com) will demonstrate its expanded GEN3SYS high penetration drilling system. The increased range for this tool is now 12 mm to 32 mm, with 3-, 5- and 7-times drill depth–todiameter ratios with straight and helically fluted holders. The AM200-coated tools are designed to provide good chip formation, high penetration rates, and a long tool life.
