Stiff platform for wheel dressing
As a replacement on Heald CF internal grinding machines, the heavy-duty lift-up dressing system (HDLU) sports a one-piece cast-iron body and largediameter pivot shaft with extra-wide bearing spacing for maximum stiffness. The system dresses conventional g
As a replacement on Heald CF internal grinding machines, the heavy-duty lift-up dressing system (HDLU) sports a one-piece cast-iron body and largediameter pivot shaft with extra-wide bearing spacing for maximum stiffness. The system dresses conventional grinding wheels or superabrasives. The unit also has a precision-keyed nosepiece that accepts any dressing device for quick peripheral-device changeovers without having to change complete assemblies.
Service Network Inc.
Worcester, Mass.
sni-grinders.com
