The DMV 3016L VMC from Doosan Infracore Co. Ltd. packs the power for heavy cutting in tough materials. Its 20-hp motor delivers 12,000 rpm to a 40-taper, cartridge-type spindle. Power transfers through a cogged drive belt, which eliminates slippage and vibration while promoting thermal stability. An encoder attached to the spindle provides synchronized, depth-controlled high-speed rigid tapping using standard collar chucks.
