Kerk Motion Products Inc.
Kerk Motion Products Inc.’s new SS2 spline shaft series has an outside diameter of 0.125 in. (3.18 mm) making it the smallest spline shaft in its line. Kerk says the new spline shaft is designed for light load applications where low cost, ...
Kerk Motion Products Inc.’s new SS2 spline shaft series has an outside diameter of 0.125 in. (3.18 mm) making it the smallest spline shaft in its line. Kerk says the new spline shaft is designed for light load applications where low cost, low friction and long life are critical design considerations.
www.kerkmotion.com
