Space-saving tester
Satec single-footprint, hydraulic, universal-testing systems combine frame, hydraulic-power supply, electronics, and control panel into a single machine. This reduces floorspace by more than 60%.
The hydraulically powered load frames of the Satec DX line include two test spaces, so tension and compression tests are done in separate areas. Users can change tests without removing heavy fixtures.
The rigid two-column load frames of the Satec LX models provide a large testing space that accommodates specimen sizes at a comfortable working height.
Instron
Grove City, Pa.
instron.com
