Wire EDM tackles intricate machining
UP32i wire EDMs machine tackles items that require extensive and intricate machining such as high-accuracy precision parts, progressive dies, and engineered plastic molds. Makino's Crystal Machining Circuit provides high-definition surface finishes down t
UP32i wire EDMs machine tackles items that require extensive and intricate machining such as high-accuracy precision parts, progressive dies, and engineered plastic molds. Makino's Crystal Machining Circuit provides high-definition surface finishes down to 3-µin. Ra with no special tooling, jigs, or fixtures. The machines burn guide-pin holes equal to that of jig grinding.
Makino
Mason, Ohio
makino.com
