No secondary operations
Nakamura-Tome Super NTJ turning centers perform multiface angular machining and contour milling in single setups to eliminate refixturing on other machines for secondary operations. With Luck-Bei II software, these B-axis machines do nine-axis machining w
Nakamura-Tome Super NTJ turning centers perform multiface angular machining and contour milling in single setups to eliminate refixturing on other machines for secondary operations. With Luck-Bei II software, these B-axis machines do nine-axis machining with simultaneous 4+4 axis control.
Methods Machine Tools Inc.
Sudbury, Mass.
methodsmachine.com
