Finishing tools for steel
Rex-Cut Products Inc. says its Rex-Cut Double-Cut carbide burs remove exit burs from drilled holes on stainless steel, high nickel alloys, common steel tubing and cast iron pipe.
Nov. 10, 2005
Rex-Cut Products Inc. says its Rex-Cut Double-Cut carbide burs remove exit burs from drilled holes on stainless steel, high nickel alloys, common steel tubing and cast iron pipe. The company says the tools do this with less vibration than conventional tools and produce fine chips and smooth finishes while being easy to control. The company says its tools are designed to fit standard straight and right-angle die grinders. www.rexcut.com
