Sandvik Coromant
Sandvik Coromant says its GC4235 grade is the toughest, most versatile grade in its family of steel turning inserts. Its improved edge line security, optimized coating and substrate result in high resistance to deformation. ...
Sandvik Coromant says its GC4235 grade is the toughest, most versatile grade in its family of steel turning inserts. Its improved edge line security, optimized coating and substrate result in high resistance to deformation. (www.coromant.sandvik.com/us)
