Rigid VMC
The Vertex 550-5X 5-axis VMC's casting provides a rigid machine structure. Its gear-drive system for A and C rotary axes deliver high-speed radial performance and overall drive-system stiffness. The A trunnion-tilt axis also has ample dual-side support co
May 1, 2005
The Vertex 550-5X 5-axis VMC's casting provides a rigid machine structure. Its gear-drive system for A and C rotary axes deliver high-speed radial performance and overall drive-system stiffness. The A trunnion-tilt axis also has ample dual-side support construction that further boosts rigidity. With the A and C rotary-and-tilt axes, the Vertex 550-5X provides five integrated axes of motion for one-setup machining of complex parts, such as those in automotive, aerospace, medical, and mold/die industries.
Mitsui Seiki USA Inc.
Franklin Lakes, N.J.
mitsuiseiki.com
