DP Technology Corp. CAM Software
ESPRIT 2006 is upgraded with new grooving cycles to support advances in cutting tool geometry and machine tool design, including machines capable of turning while utilizing a B-axis. ESPRIT Mold uses 20 different milling strategies to ...
ESPRIT 2006 is upgraded with new grooving cycles to support advances in cutting tool geometry and machine tool design, including machines capable of turning while utilizing a B-axis. ESPRIT Mold uses 20 different milling strategies to automatically manage the in-process stock model, allowing the user to combine milling strategies from 2-axis to 5-axis for optimized tool paths. 3+2 Machining in ESPRIT Mold improves surface finish by using A-and Baxes to incline the cutting tools, making the use of shorter, more rigid cutting tools and direct machining of undercut areas possible.
