Machine Provides Control and Accuracy
Aug. 5, 2005
The SV-1000 vertical honing system from Sunnen Products Co. sports a tool-stroking system that reportedly delivers more control and accuracy in geometry, size, and finish for 0.120 to 2.56-in.-bore applications. There is a 3-axis handwheel control to fine-tune vertical stroke position and honing tool feed position for quick setups. Applications include fuel injectors, hydraulic valves and valve bodies, and transmission and other precision gears.
