Bimetal bandsaw blades
Bimetal Gladiator bandsaw blades have a wear and heat-resistant backing and tripletempered M42 high-speed steel teeth with 8% cobalt (67 to 69 Rc) and up to a 12° rake angle. The blades reportedly deliver easy penetration, good chip clearance and sur
Bimetal Gladiator bandsaw blades have a wear and heat-resistant backing and tripletempered M42 high-speed steel teeth with 8% cobalt (67 to 69 Rc) and up to a 12° rake angle. The blades reportedly deliver easy penetration, good chip clearance and surface finish, and fast, straight cuts.
Gladiator blades are for highproduction cutting of shapes, solids, and tubing from mild to 42 Rc steels and nickel-based and nonferrous alloys. They come in seven widths and thicknesses from 3/4 0.035 to 31/8 0.063 in. Gladiator Pulsator blades, with teeth providing an aggressive, surging action, cut large, solid sections of exotic and nickel-based alloys and hardened steels. They come in six widths and thicknesses from 1 0.035 to 31/8 0.063 in.
L.S. Starrett Co.
Athol, Mass.
starrett.com
