Vise with hydraulic power booster
The Arnold twin high-pressure vise clamps one or two parts. Users manually clamp a part in either of the two stations, and a spring mechanism holds it while another part is loaded. Turning the vise handle applies hydraulic pressure to grip the parts. The
The Arnold twin high-pressure vise clamps one or two parts. Users manually clamp a part in either of the two stations, and a spring mechanism holds it while another part is loaded. Turning the vise handle applies hydraulic pressure to grip the parts. The vise mounts horizontally, vertically, or on either side. Length of workpieces can differ by 3 mm, or less.
Fresmak S.A.
Gipzukoa, Spain
fresmak.com
