Jorgensen Conveyor and Filtration Solutions
Jorgensen Flex G Series modular filtration system.
Pre-Engineered Modules For Fast, Easy, Flexible Filtration
March 17, 2022
Efficiently remove fine chips and grinding sludge to achieve coolant clarity down to 10 microns or less, for applications involving cast iron, steel, aluminum, composites, and plastics.
JORGENSEN CONVEYOR and FILTRATION SOLUTIONS introduced its new FlexFiltration line that also includes the new Flex G Series of modular filtration systems. These cost-effective systems feature pre-engineered modules that ensure fast, easy and flexible filtration system configurations for practically any filtering application.
FlexFiltration systems efficiently remove fine chips and grinding sludge to achieve coolant clarity down to 10 microns or less. They are especially well suited for applications involving materials ranging from cast iron, steel and aluminum to composites and plastics.
Jorgensen has developed several pre-engineered base configurations that allow customers to construct a FlexFiltration system specific to coolant-flow requirements. To further match the system to the intended application the company offers a range of system tanks, including standard or low-profile versions along with an optional stainless-steel tank that makes the new FlexFiltration system ideal for machine tool OEMs and end users alike.
Other modular options that complete a system include high-pressure pumps, auxiliary pumps, tramp oil skimmers, coolant chillers, heat exchangers, liquid level sensors, temperature sensors, and the ability to control/interface with existing pumps and other equipment.
Included in the FlexFiltration introduction is Jorgensen’s Flex G Series systems featuring gravity media filters. The gravity media-filtration option is the first one available in the FlexFiltration product line. Gravity filters are offered in 30, 60 and 90 gpm options and come standard with low media roll detection, no media alarm sensor, and automatic roll advance. A variety of different disposable cloth medias also are available based on specific applications.
Learn more at www.jorgensenconveyors.com
Latest from New Products
Inovatools Eckerle & Ertel
ATI Industrial Automation
ATI Industrial Automation’s patent-pending MC-50 manual tool changer.
Hamar Laser Instruments
The Hamar Laser Instruments L-703SP compact geometry, laser-based calibration system.
ECM PCB Stator Tech
An rotary electric motor with a PCB stator in place.
