GWS Tool Group
Np Gws Tool Hurrimill Promo
High-Performance, Solid-Carbide End Mill
Sept. 16, 2021
Hurrimill AT4 end mill is recommended for slotting and profiling, ramping, plunging, high-speed milling, and roughing and finishing.
GWS TOOL GROUP introduced the Hurrimill AT4 all-terrain end mill, a four-flute high-performance, solid-carbide end mill for ferrous and nonferrous machining applications.  This new end mill is engineered for dynamic milling or conventional roughing, including slotting up to 2xD.
Radial end gashing enables drilling, steep ramping, and aggressive helical entry. Whether it’s slotting, profiling, ramping, plunging, roughing, finishing or high speed milling, the Hurrimill AT4 all-terrain end mill is designed to handle any ferrous and non-ferrous materials.
The Hurrimill AT4 end mill is recommended for slotting and profiling, ramping, plunging, high-speed milling, and roughing and finishing. Learn more at www.gwstoolgroup.com
Latest from New Products
Inovatools Eckerle & Ertel
ATI Industrial Automation
ATI Industrial Automation’s patent-pending MC-50 manual tool changer.
Hamar Laser Instruments
The Hamar Laser Instruments L-703SP compact geometry, laser-based calibration system.
ECM PCB Stator Tech
An rotary electric motor with a PCB stator in place.
