Absolute Encoders with Digital Read Out
DROs allow machine operators to read the position where machining stops, even when power is turned off or lost.
KBC TOOLS & MACHINERY is offering absolute encoders with digital read outs (DROs) that allow machine operators to read the position where machining stops, even when the power is turned off or lost during an outage or electrical shut-off. It’s no longer necessary to return to a zero reading, no matter where you are in your machining path.
Igaging EZ-View DRO Plus digital scales with remote readouts for horizontal or vertical measurements, with absolute encoders are available with measurable ranges of 0-6 in./150 mm, 0-12 in./300 mm, 0-24 in./600 mm, 0-36 in./900 mm from KBC Tools & Machinery. They offer resolutions of 0.0005 in. / 0.01 mm / 1/128 in. Igaging EZ-View DRO Plus digital scales with remote readout kits come complete with on/off button, present button, hold button, origin button, a 76-in. remote cable length, mounting brackets, 3V CR2032 battery, and an articulating arm to allow for stacking multiple displays.
The six key LCD display units come with magnetic strips to allow for quick, magnetic attachment to steel surfaces.
The EZ-View DRO has SPC/USB data output, and can be easily attached to your computer by an SPC/USB cable data kit or a wireless data kit (available as optional accessories), to log your output without antiquated paper-based logbooks. An AC power supply is available as an optional accessory.
Learn more at www.kbctools.com
