Automated CNC Door Opening for Robots
Made4CNC’s new Safedoor SD100 removes the barriers to the automation of component feeding at machine shops. Safedoor SD100 opens CNC doors that are up to 1 meter wide and weigh 400 kg, at a speed of 500 mm/s. The door opener can connect to any robot and CNC machine via galvanic insulated digital inputs and outputs.
When automating CNC machines today, integrators often build “homemade” door opening solutions. But that risks errors, stoppages, and hazardous situations because the solutions typically require compressed air and are neither standardized nor tested. These challenges are overcome with Made4CNC’s fully electric Safedoor SD100 with built-in safety functions that enable the integrator to adjust the speed of the CNC door, making risk assessments easier to conduct.
“Around the world the need for faster and greater automation is a major trend, and for it to succeed, less time must be spent on each installation,” said Peter Nadolny Madsen, CEO at Made4CNC. “With the SD100, we have integrated safety and robustness in a user-friendly solution, which we believe is the key to optimal productivity,” he said, adding that integration of collaborative robots or light industrial robots together with existing CNC machines makes a lot of sense, since the automation of existing machines generate low risk and a short payback period for the customer.
Integrator Nordelektro has installed two Made4CNC Safedoor SD100 door opening solutions at Randers Tandhjulsfabrik. “It took less than an hour for each CNC machine and they are good and stable door openers,” reported Lars Bo Nielsen, factory manager at Randers Tandhjulsfabrik. For Nordelektro, it makes a difference that they can provide customers with a standardized solution designed as a solution-in-a-box:
“Safedoor SD100 is a complete solution, which makes it simpler to work with automation,” said Jesper Storm Simonsen, sales manager at Nordelektro. “It is a huge advantage for us as an integrator. We don’t need to invent something complicated and expensive. We have minimum project risk.”
Made4CNC has entered into agreement with its first American distributor, Thinkbot Solutions: “Safedoor SD100 makes having a job as a machine feeder much more pleasant and easy-going, while the employer will be able to optimize and get a better work flow,” said president of Thinkbot Solutions, Philip Courtois. “Others have tried unsuccessfully to develop a user-friendly door opener. Made4CNC has completely succeeded. I have chosen to distribute SD100 because attention is given to all of the details in terms of the mechanics, software and safety,” he stated, adding that SD100 is certified by collaborative robot company Universal Robots (UR). “The UR+ certification ensures completely seamless integration with robots from Universal Robots. All operation can be done through the robot’s teach pendant.”
Learn more at www.made4cnc.com/
