Machine Safety Guards with Built-In LED Lighting
FLEXBAR MACHINE CORP. introduced a new line of state-of-the-art machine safety guards featuring built-in LED lighting providing machine operators with “super bright” illumination of the working field. The Visorguard-LED’s continuous strip lighting is integrated as part of the safety shield, providing 6,000 K natural white light with a 170-degree beam angle. Auto-diffuse lighting produces no LED light hot spots.
Flexbar’s Visorguard-LED™ system is water- and coolant-proof and installs in minutes on CNC mills, conventional mills, drill presses, and more. The adjustable Flexbar® arm permits setting of the Visorguard shield at the correct height and angle for each set-up, then locks rigid. The special, wing-shaped shield flips up to load a part and down for machining. A special spring-loaded shaft allows the shield to stay put with no springback.
The built-in Visorguard-LED™ lighting is powered through a choice of two available system options:
- A compact, 12-V rechargeable battery pack with on/off switch provides at least four hours of lighting per charge. It can be attached easily to the shield’s side wing with included Velcro strips. A 12-V charger is included, too.
- The system can be powered through a 12-V direct-wire wall transformer with an 8-foot cable and on/off switch.
Replacement Visorguard-LED™ shields and power kits are available for current Flexbar Visorguard users who can conveniently upgrade their current system to LED lighting.
All guards meet or exceed OSHA requirements. Learn more at www.flexbar.com
