Dana Inc.
Dana Spicer Eaxle 800 5e5466efa3c17
Dana Producing e-Axles for Medium-Duty Trucks
Feb. 25, 2020
The start of production for eS9000r e-axles lets Dana claim to be "first to market in North America" with a drop-in electronic propulsion system for current Class 4 and 5 commercial vehicles.
Dana Inc. has started manufacturing its Spicer Electrified eS9000r e-axle for Class 4 and 5 commercial fleet applications, and claims this positions itself as the "first to market in North America" with an axle technology for medium-duty commercial electric vehicles, meaning Class 4 and Class 5 trucks. These are medium-duty trucks used as transport and delivery vehicles, often referred to as "box trucks"
Dana further declared it is the only supplier able to manufacture all components of an e-axle system, including gears, axle, motor, and inverter.
The e-S9000r is a fully integrated "e-axle", including gearbox and motor, based on Dana's Spicer® S110, S111, and S130 rear-drive axle systems. It can be incorporated as a "drop-in solution" for most medium-duty truck chassis, offering a less complex driveline while allowing batteries to be located between the frame rails.
It also incorporates a patent-pending, electronically controlled parking pawl system, which links and loks an automatic transmission system.
The e-S9000r is engineered as a "drop-in solution" for existing commercial-vehicle suspension systems.
According to Mark Wallace, president of Dana Commercial Vehicle Drive and Motion Systems, the manufacturer expects the medium-duty truck class to be the first to deploy electric-vehicle technology on a wide scale.
The e-Axle will be available for ordering by vehicle manufacturers in 3Q 2020.
Ian Ward | Rivian Automotive
Rivian Automotive side panels, Normal, Ill.
Lockheed Martin
Lockheed Martin built NASA’s Orion Artemis II crew module, crew module adaptor, and launch abort system.
Huntington Ingalls Inc., Newport News Shipbuilding
Virginia-class nuclear sub.
