Streamlined Five-Axis Performance
The Mikron HPM 450U is described as a “sturdy and compact” design with a large work envelope. The maximum X-Y traverse path is 23.62×17.2 in., and the Z-axis has a clearance of 17.72 in. between the table surface and spindle nose.
The machine’s rotary table speed is 140 rpm, and its tilting range is -120/+45.
The Step-Tec spindle designed for the machine is available as two options: a 12,000-rpm version with an ISO 40 taper, for conventional tooling technologies and programs; or, a 20,000-rpm version with an HSK-A63 taper for machining a wider range of materials. Both spindle options have vector control functionality for full torque in lower speed ranges; a “highly stable” ceramic hybrid spindle bearing; and spindle casing cooling that uses a controlled internal coolant system to maintain temperature consistency.
The Mikron HPM 450U has several options for tool magazines, so it will accommodate single-piece machining programs as effectively as mass production of complex workpieces. An internal tool changer integrates into the machine’s base and will store up to 60 tools. There is also an external, circular magazine that increases the storage capacity to 220 tools. Coupling the external magazine with an optional automatic pallet-changing magazine creates a flexible manufacturing cell capable of unmanned production, according to GF AgieCharmilles.
The Mikron HPM 450U’s ergonomic design includes a protective enclosure and large windows, so operators have full view of production. As a nod to its high-performance machining potential, the machine is designed for full control of chips by way of its 13.8-in. wide scrap conveyor, an edge filter positioned inside the internal coolant system to separate chips from the coolant, and protection from “chip overload” via an automatic return function to lessen the effects of any possible chip buildup.
Process control is supplied by a Heidenhain iTNC 530 digital control system, which the developer said makes the Mikron HPM 450U “user friendly.” The system has an Ethernet connection for fast CAM data delivery, dialog-controlled programming, as well as parallel programming and definable sub-programming.
