[IMTS Preview] MAG Industrial Automation Systems Presents Big Bore CNC Lathe
MAG's new VDF 800 DUS Big Bore CNC lathe is engineered for a life of energy-industry work with 365 mm (14 inch) spindle diameter, 820 mm (32 inch) swing over the bed, 8,000 kg (17,600 lb) part capacity, and 20 kN (4,500 lb) Z-axis cutting force. Ideal ...
MAG's new VDF 800 DUS Big Bore CNC lathe is engineered for a life of energy-industry work with 365 mm (14 inch) spindle diameter, 820 mm (32 inch) swing over the bed, 8,000 kg (17,600 lb) part capacity, and 20 kN (4,500 lb) Z-axis cutting force. Ideal for drill string parts, drive shafts and pipes, the machine has a main drive rated at 37 kW (50 hp) continuous, 55 kW (74 hp) maximum with 7,200 Nm (5,300 ft lb) maximum torque. A 900 rpm top speed gives the machine job-shop flexibility to handle a wide range of smaller diameter parts by maintaining the tool surface speeds needed to produce required finishes. The two-speed automatic transmission is mounted behind the headstock to eliminate thermal effects caused by the gearing, with a backlash-free overload coupling to protect the gearbox. The machine's A20 spindle is supported with a thermally optimized arrangement of lifetime-lubricated bearings that includes a 460 mm (18 inch) diameter front bearing to comfortably withstand maximum loads and speeds.
The VDF 800 DUS is available with a Siemens or Heidenhain CNC, which is supplemented with an operator panel and ergonomically designed hand wheels for setup or teach-type programming.
The VDF 800 DUS is built on a torsionally stiff, box-type Meehanite cast iron bed, 560 mm (22 inch) wide that retains its core sand to enhance vibration damping for longest tool life and smooth part finishes. Hardened double-V guide ways and an oversized cross slide provide high stability for the tool carrier and distribute high axial cutting forces to prevent skewing.
The VDF 800 DUS Big Bore is available with turning length sizes of 1, 2, 3 and 4 meters (3.3, 6.6, 9.8, 13.1 ft) as standard, and up to 20 meters (65.6 ft) optional.
