New Bridge Machines for Precision Milling
ZIMMERMANN MILLING SOLUTIONS will virtually show three new gantry machines at IMTS 2022 - booth 339336 – including the largest model, the FZ42 CNC gantry milling machine that “represents power at its best, combining work areas of different sizes, travels, milling heads and CNC controls.”
Regardless of the part’s weight or size, the milling process is precise with the FZ42 CNC. Furthermore, the gantry design is particularly suitable for the entire range of component machining. The structurally rigid center-guiding gantry, cross and Z-Ram, and dynamic milling head allow consistent, efficient milling processes. This combination of high thermal stability and rigidity meets industry-specific requirements in tool-and-die making, aerospace and automotive industries.
Strength and agility also are demonstrated in the newest high-performance gantry FZ37. Due to its modular system concept, the FZ37 is available in various sizes, custom configuration and CNC controls. The newly designed gantry with center guided Z-Ram in combination with Zimmermann’s dynamic milling heads ensure an efficient and consistent milling process. The high thermal stability and rigidity meet industry-specific requirements in model, tool and die making as well as in the aerospace and automotive industries.
The FZ32 is a high-performance gantry system for dynamic machining of aluminum, fiber composites, plastics, and tooling board. Its thermo-symmetrical design results in high surface quality and accuracy. The rigid center-guiding gantry allows machine operators to meet the increasing demands in model and mold making as well as aerospace.
Additionally, the flexible design of the FZP machine line offers various sizes and configurations through its modular system as well as extensive equipment options and a fully enclosed work area, including effective dust extraction systems and more.
Get more information at www.zimmermann-inc.com
