Protect test equipment from vibration
Kinetic Systems designed its Series 9211 personal vibration isolation workstations to be stable bases for roundness checkers, surface profilometers, balances and other equipment used in a variety of industries. The workstations feature the company's ...
Kinetic Systems designed its Series 9211 personal vibration isolation workstations to be stable bases for roundness checkers, surface profilometers, balances and other equipment used in a variety of industries. The workstations feature the company's Active-Air Suspension system — a dual-chamber, compressed air system — that provides vibration dampening and maintains a preset level that the company says compensates for load changes. The workstations can accommodate loads up to 440 lbs. www.kineticsystems.com
