2D and 3D laser cutting
Domino HS 1530 multi-axis, high-speed laser systems from Prima Laser Tools provide 2D and 3D laser cutting. They cut flat and shaped parts, and bevel cut.
Domino HS 1530 multi-axis, high-speed laser systems from Prima Laser Tools provide 2D and 3D laser cutting. They cut flat and shaped parts, and bevel cut. The machines' positioning accuracy and repeatability is 0.001 in. with combined positioning speeds of 5,900 ipm. In spite of a compact size due to their cantilever designs, Domino HS systems provide large (1203 60 3 16-in.) work areas. System laser heads do two rotations — 360° continuous A-axis and ±135° B-axis.prima-na.com
