Robotic arc-welding system
The PerformArc 122S robotic arcwelding system features a six-axis arc-welding robot. The integrated robot controller is digitally interfaced with a Panasonic 350-amp, artificialintelligence inverter. Other equipment includes a heavy payload/high-speed/AC
The PerformArc 122S robotic arcwelding system features a six-axis arc-welding robot. The integrated robot controller is digitally interfaced with a Panasonic 350-amp, artificialintelligence inverter. Other equipment includes a heavy payload/high-speed/AC servo-controlled turntable with 440-lb (200-kg) AC servo headstock/tailstock mounted onto the positioner. The 122S is compliant to RIA 1506.1999, UL1740, CSA Z434, and NFPA79.
Panasonic Factory Automation Co.
Elgin, Ill.
panasonicfa.com
