Waterjet controls pressure changes
The Model 55-50C intensifier pump features an attenuator that minimizes pressure fluctuations. The pump's hydraulic system uses an electronically shifted, plunger-style intensifier that delivers 1.1 gallon per minute at 55,000 psi to various cutting or cl
The Model 55-50C intensifier pump features an attenuator that minimizes pressure fluctuations. The pump's hydraulic system uses an electronically shifted, plunger-style intensifier that delivers 1.1 gallon per minute at 55,000 psi to various cutting or cleaning tools. An integrated water filter and booster eliminate connections between other filtration systems. A PLC monitors and controls machine functions. The Model 55-50C handles two 0.011-in. orifices or one 0.016-in. orifice.
Jet Edge
St. Michael, Minn.
jetedge.com
