No-slip grooving inserts
Dovetail clamping systems of Groove 'N Turn inserts prevent slippage or rotation during axial or radial cuts. Built-in stops also prevent movement in pockets during cuts. Available single or double-ended, the inserts come in two submicron-grain carbide gr
Dovetail clamping systems of Groove 'N Turn inserts prevent slippage or rotation during axial or radial cuts. Built-in stops also prevent movement in pockets during cuts. Available single or double-ended, the inserts come in two submicron-grain carbide grades — DM-2 for steel and interrupted cutting and DM-5 for aluminum and other nonferrous alloys.
Kaiser Tool Co. Inc.
Ft. Wayne, Ind.
thinbit.com
