Vegetable-oil-based metalworking fluid
Vasco, a vegetable-oil-based metalworking fluid, reportedly surpasses other water-miscible cutting fluids. It is well-suited for difficult machining and grinding applications and surface tolerance requirements. Blaser Swisslube also produces Blasocut emul
Vasco, a vegetable-oil-based metalworking fluid, reportedly surpasses other water-miscible cutting fluids. It is well-suited for difficult machining and grinding applications and surface tolerance requirements. Blaser Swisslube also produces Blasocut emulsions as well as Blasomill and Vascomill cutting oils.
Blaser Swisslube Inc.
Goshen, N.Y.
blaser.com
