Self-centering punch/die sets
TruPunch self-centering punch-and-die sets feature pilot systems for perfect alignment when producing custom washers and shims. Operators simply punch the inside hole, insert the matching pilot into the tip of the outside punch, and then punch the outside
TruPunch self-centering punch-and-die sets feature pilot systems for perfect alignment when producing custom washers and shims. Operators simply punch the inside hole, insert the matching pilot into the tip of the outside punch, and then punch the outside hole. Available in three configurations, TruPunch sets cut steel, brass, copper, aluminum, and stainless.
Precision Brand Products Inc.
Downers Grove, Ill.
precisionbrand.com
