Cutters For Milling Cast Iron
CoroMill 365 facemilling cutters from Sandvik Coromant Co. are designed for roughing and semifinishing of cast iron.
CoroMill 365 facemilling cutters from Sandvik Coromant Co. (www.coromant.sandvik.com/us) are designed for roughing and semifinishing of cast iron in large series production or high-volume applications, and can be used in machining centers or transfer lines.
The company says the CoroMill 365 wedge clamp design and close-pitch cutters allow for machining at high table feedrates. The cutters' Multi-Edge concept contains eight cutting edges that produce-burr and frittering-free machining-with up to 0.24-in. depth-of-cuts. They are available in diameters from 1.97 in. to 6.3 in
