How SMB Manufacturers Are Engineering Resilience
Key Highlights
- Manufacturers face multiple simultaneous pressures, including supply chain disruptions, rising costs, and cybersecurity threats.
- Digital transformation, especially through ERP systems, is critical for connecting business functions and reducing manual work, enabling better decision-making.
- Protecting workforce knowledge and automating administrative tasks help SMBs scale expertise and focus on strategic problem-solving.
- Cybersecurity must be integrated into daily operations, with focus on access control, updates, and workforce awareness to prevent costly downtime.
- Cost discipline and accurate cost tracking are essential for maintaining profitability amid tariffs and market uncertainties, emphasizing the need for better feedback loops.
For small and mid-sized manufacturers, it may seem that the only real economic certainty is uncertainty. Every week it shows up a little differently: schedules that change midweek, suppliers who shift lead-times without much warning, teams that are stretched beyond the limits they hit even a few years ago. What makes the present moment different is not that these pressures exist. It’s that they’re all arriving at once.
Cost pressure, labor constraints, cybersecurity risk, supply chain volatility, and rising customer expectations are no longer separate problems. They’re a single, compounded operating reality.
A number of data sources show just how the pressure continues to build. A recent Supply Chain Planning Benchmark Report found that nearly two-thirds (63%) of small and mid-sized manufacturers reported direct operational impacts from tariffs during 2025. Turbulence of that sort will continue this year.
At the same time, cybersecurity has moved beyond a theoretical risk and is firmly fixed as a top concern: nearly half (46%) of small and medium-sized businesses globally have already suffered a cyberattack, and roughly one in five of those victims ultimately filed for bankruptcy or closed their doors. Each issue is layered on top of the most familiar workforce challenge, where a recent Deloitte survey of manufacturing leaders found that more than one-third of them cite upskilling and workforce readiness as their top priority.
Put simply, resilience is no longer about solving one external problem but being able to operate amid many problems all at once.
No doubt that’s easier said than done. The reality of such a complex manufacturing ecosystem is that it exposes many limitations of how many machine shops have customarily operated: with disconnected systems, manual workarounds, and too much critical knowledge locked in the heads of a few people.
Digital transformation is not effected by chasing technology trends. It’s becoming a practical requirement for running the business without constant fire drills, margin surprises, or missed commitments.
Systemizing the flow of information
Evaluating the need for digital transformation often starts with a close look at how information moves throughout the business. While older data-management techniques (pen and paper, spreadsheets, whiteboards, and one-off emails) may have worked under stable conditions, but today such disconnection constitutes a major risk. When labor is tight and variability is high, manufacturers cannot afford to spend hours reconciling numbers, re-keying data, or debating which version of the schedule is correct.
Today’s modernization should focus on connecting the core elements of the business. For most manufacturers, that will start with an enterprise resource planning (ERP) system that ties together day-to-day operations, from scheduling and job-costing to inventory, purchasing, production, and accounting. Those core functions do not need to be perfect but must be working from the same source of certainty. When they are, the business stops arguing with its own data, and external problem solving becomes simpler.
Building resilience around people
By no means a new challenge for SMB manufacturers, the labor challenge has evolved into something deeper than headcount. The core concern beyond staffing is a problem of knowledge continuity. Experienced people are retiring or moving on, and the work itself has become more complex.
Critical processes that live in someone’s memory or in a personal spreadsheets linger now as weak points.
Technology, in this context, is about protecting employees’ time and scaling their impact. When systems take on more of the repetitive administrative work (tracking, documentation, updates, coordination), employees can focus on judgment, problem-solving, and improvement. With this methodology, SMBs can systemize not just production but expertise too.
Cybersecurity interwoven with operations
As more of the operation becomes connected, cybersecurity advances beyond simply an IT concern. It must be the focus of the entire operation. When machines, planning systems, suppliers, and customers are digitally linked, downtime reaches far and wide, with the means to affect everything from production to shipping, and even invoicing. Serious instances have significant bottom-line impacts.
Under the lens of digital transformation, the core consideration is whether the basics are solid: access control, updates, backups, and a workforce that knows how to spot obvious threats. In a connected shop, resilience includes the ability to keep running and recover quickly, not just the hope that nothing goes wrong.
Turning cost pressure into cost discipline
Layered on top of all of this is renewed pressure from tariffs and broader supply-chain uncertainty. Many manufacturers are discovering, sometimes painfully, that they cannot simply pass every increase through to customers. That makes discipline around job-costing, quoting, and purchasing as important as ever.
The practical response is not to try to predict every policy change or market shift. It’s to systemize how the business understands its own costs. Better feedback loops between what was quoted, what was built, and what it actually took to do the work are becoming essential to staying profitable.
The shift moving forward
When you step back, a clear pattern emerges in the ways that SMB manufacturers are responding to today’s pressure. They’re focusing less on big, disruptive overhauls and more on a few fundamental parameters: gaining clarity about which work is truly profitable, building schedules that reflect reality instead of optimism, and removing everyday friction that slows teams down. Operational resilience means fewer manual handoffs, fewer surprises, and more time spent solving problems instead of reconciling information.
Artificial intelligence is starting to support this shift but in practical and tactical ways. For most manufacturers, the value is in using technology to take routine work off people’s plates - whether that is improving documentation, reporting, analysis, or communication - so teams can focus on better decision-making. Used this way, AI becomes another tool for making the business more responsive and connected. Resilience in 2026 is being built directly into how the business runs, so that inevitable disruptions do not drive such uncertainty.
Paul Farrell
Senior Vice President of Product Management
Paul Farrell is the Senior Vice President of Product Management at ECI Software Solutions, a cloud-based, industry-specific ERP software for small and medium-sized businesses (SMBs)
