The Benefits of Multi-Channel Vibration Measurement
April 26, 2012
3- and 4-channel data collection and condition monitoring equipment helps plants cut maintenance costs and increase productivity
The old adage that “Time is money” is a hard fact of life for many plant operators who must deal with the possibility of equipment breakdowns and loss of productivity as part of their daily routine.
Particularly in the current economy, such occurrences go directly to a company’s bottom line. Thus, the need for a reliable and effective condition-monitoring program to protect a facility’s all-important maintenance and operations is a key consideration.
Choosing the right maintenance program and the right equipment is crucial to minimizing the costs of equipment maintenance and achieving optimum utilization of maintenance and operations personnel. Plant engineers and maintenance personnel need a diagnostic tool that quickly and reliably measures and stores readings that detect changes in a machine’s health and performance. Ultimately this will lead to increased plant uptime and enhance profitability.
Traditional single- or dual-channel data collectors offer what can be a slow, cumbersome process for maintenance personnel who may be hard-pressed to perform their assigned monitoring tasks as quickly as possible.
For example, to measure vibrations on a motor pump, standard practice requires placement of the single vibration sensor – on the non-drive end of the motor pump in the horizontal plane. When the data collector provides its results, they are compared against a pre-defined alarm limit and stored in the data collector. Next, the vibration sensor is repositioned to the vertical plane, where the process of measuring, comparing and storing is repeated. To complete the motor pump assessment, the sensor will need to be repositioned multiple times – once for each measurement point required along the machine train. For a large plant with several machines to survey, such a single-channel practice would take incrementally more time to complete the task.
Using a multi-channel data collector/analyzer with a tri-axial sensor can speed up the process significantly. A tri-axial sensor consists of three independent sensors placed at 90 degrees to each other and wired out on a multi-pin connector. Using a tri-axial sensor eliminates the need to relocate the sensor in between the horizontal, vertical and axial locations, ultimately consolidating them into one location. As a result, three planes can be recorded simultaneously in the same amount of time that it takes to record one reading with a single-channel data collector.
Another key advantage that a multi-channel data collector offers is the ability to observe the operating deflection shape (ODS) of a machine. An operating deflection shape is an animated picture that illustrates the machine’s movement, where it is moving the most, and the area in which the deflection modes (flexible or rigid body) are present. Due to its illustrative characteristics, ODS analysis also can provide quick insight into the movements and the associated problems of the machinery structure as a function of frequency. As such, it can be a very powerful analytical tool.
Modern data analyzers such as the SKF Microlog Analyzer AX feature special analysis software programs to perform ODS analysis according to a structured procedure. In addition to industry-proven SKF Acceleration Enveloping (gE) technology, the Microlog AX provides the capabilities of 4-channel non-route/1- to 3-channel or simultaneous triaxial route analysis and 2-channel balancing. Users can select from a range of application modules, creating a custom device that suits their specific requirements. Modules can be added as a user’s needs evolve, thereby increasing the value of the hardware investment by upgrading capabilities without the need to buy a new instrument. Application modules include Balancing; Frequency Response Function; Run up/Coast down and Check to Conformance. This range of application modules allows users to perform a range of advanced tasks, including digital recording, modal analysis, transient phenomena analysis, and quality inspections – all with the same device.
Whether a facility is just beginning an analysis program or has senior analysts with a wealth of experience, the SKF Microlog AX offers functionality and flexibility that fits. New users can benefit from the speed, accuracy and consistency of tri-axial and multi-channel measurement capabilities, while advanced users can get some of the highest quality analysis capabilities available all in one full-featured instrument.
When machinery goes down, so does productivity and overall profitability. Three- and four-channel data collectors increase the speed and efficiency of data collection and measurement to detect machine health and performance in a way that is easy to use and read. As more and more operations utilize this innovative tool, their ability to optimize both personnel time and maintenance costs grows, with the result being increased savings and a better bottom line.
Paul Edwards is the principal engineer at the SKF Condition Monitoring Centre in Livingston, England, tel. +44 (0) 1506 470011, which designs, manufactures, and supports, the handheld electronic instrumentation that are the basis of portable SKF Condition Monitoring vibration products available worldwide through SKF Reliability Systems. SKF is a global supplier of bearings, seals, mechatronics, lubrication systems, and services, including technical support, maintenance and reliability services, engineering consulting, and training.
Latest from Shop Operations
BiancoBlue | Dreamstime
Divinesky27 | Dreamstime
Warut Sintapanon | Dreamstime
Spaxia | Dreamstime
