Insidepenton Com Images 85977 Rustlick
[IMTS Preview} Rustlick to Show PowerCool Green Oils
July 7, 2010
Rustlick PowerCool Green and PowerCool Green CF coolants are new, long-lasting water-soluble oils made from naturally derived, “green” vegetable-based oils. These premium coolants are specially formulated to be operator-friendly and to give maximum ...
Rustlick PowerCool Green and PowerCool Green CF coolants are new, long-lasting water-soluble oils made from naturally derived, “green” vegetable-based oils. These premium coolants are specially formulated to be operator-friendly and to give maximum lubricity, biostability in heavy-duty cutting and grinding applications. PowerCool Green and PowerCool Green CF deliver extended tool life and physical lubricity in tough operations. The advanced technology used to formulate these plant-based coolants ensures high fluid performance, increased sump life, and a decrease in overall fluid use.
PowerCool Green coolants are safe for all metals, including ferrous/nonferrous metals, aluminum, brass, bronze, and copper. These products can be used for a wide range of light to heavy-duty applications, including machining, cutting, grinding, milling, drilling, broaching, turning, threading and tapping.
PowerCool Green is available in two versions, chlorinated and chlorine free. PowerCool Green contains chlorinated EP additives; PowerCool Green CF contains non-chlorinated EP additives and is also recommended for use on titanium. PowerCool Green and PowerCool Green CF are available in 5 or 55 Gallon containers.
Visit IMTS Booth # W-2135
Latest from Shop Operations
