CNC Indexing & Feeding Technologies
AR Filtrazioni industrial air/oil filtration systems use up to seven stages of filtration to remove contaminants including oil mists, fumes and dust from the air.
Air/Oil/Dust Filtration Systems
Jan. 13, 2022
Up to seven stages of filtration remove oil mists, fumes, and dust from the air in manufacturing plants and workspaces.
CNC INDEXING & FEEDING TECHNOLOGIES is the exclusive U.S. importer for AR Filtrazioni industrial air/oil filtration systems. AR Filtrazioni manufactures systems that use up to seven stages of filtration to remove contaminants including oil mists, fumes, and dust from the air. The units improve air quality not only in manufacturing environments but also for front offices, positively affecting the health of every employee. In addition to purifying indoor air, the units also filter out contaminants that can flow out of the shop, into the atmosphere, and eventually back into soil and water.
Filtrazioni systems are easy to maintain. Only three to five minutes are required to clean and replace all filters in a typical AR Filtrazioni air filtration system, making it an excellent choice for high-volume production environments.
These systems can integrate with most CNC machine tool brands, such as Citizen, Doosan, FANUC Robodrill, Makino, Mazak, Mori Seiki, Mitsui Seiki, Okuma, and many others.
‘With more than 25,000 examples installed worldwide, Filtrazioni units are guaranteed to perform as expected,” stated CNC Indexing & Feeding Technologies president Eric Bergman.
Learn more at www.cncindexing.com
Latest from New Products
Inovatools Eckerle & Ertel
ATI Industrial Automation
ATI Industrial Automation’s patent-pending MC-50 manual tool changer.
Hamar Laser Instruments
The Hamar Laser Instruments L-703SP compact geometry, laser-based calibration system.
ECM PCB Stator Tech
An rotary electric motor with a PCB stator in place.
