OPEN MIND Technologies
hyperMILL® VIRTUAL Machining Optimizer now detects violations of the axis limitations and optimizes movement sequences accordingly.
Updates for Virtual Machining, AM, 3D Finishing, More
June 24, 2021
hyperMILL 2021.2 CAD/CAM suite includes new modules for improved machining strategies, with increased options for data feedback, while continuing to focus on user-friendly, 2.5D to 5-axis machining.
OPEN MIND Technologies AG introduced the hyperMILL® 2021.2 CAD/CAM software suite, with features for efficient, user-friendly machining in applications ranging from 2.5D to 5-axis. “With our continued focus on providing a rich, simplified user experience, the latest version of hyperMILL® offers enhanced machining strategies, increased options for data feedback, as well as more convenience,” stated Alan Levine, managing director of OPEN MIND Technologies USA Inc.
hyperMILL® Virtual Machining NC code-based machine simulation has been enhanced, too. Within the Virtual Machining Optimizer module, which links individual part programs with smooth and safe connections, the cutter is able to remain close to the workpiece, violations of the axis limitations are detected, and movement sequences are optimized accordingly. There also iso a new option in Virtual Machining to apply a special approach and retract strategy to machines where the cutting tool can be retracted into a tunnel.
OPEN MIND has introduced more capabilities in the hyperMILL® 2021.2 Additive Manufacturing module, including a Weave mode. This function generates a toolpath in a wave-shaped or zigzag movement, to apply material to contours or to fill areas, allowing the application area to be widened and the thickness to be increased for the individual movement. This continuous application also improves the metallurgical properties of the applied material.
In the integrated hyperCAD®-S CAD module additional file formats for import and export have been added, including SAT as standard ACIS text, and OBJ and 3MF for importing mesh data. Also, electrode creation has been improved via the optimized selection of the raw material. To support EDM machining, the hyperCAD®-S Electrode Converter now can be used to create import files for several EDM machines such as Exeron, Zimmer & Kreim and OPS-Ingersoll.
For increased quality and ease of use, enhancements to some CAM cycles are offered in hyperMILL® 2021.2, such as 3D and five-axis Equidistant Finishing capabilities that define the milling area by selecting bounding curves so that individual areas on a surface model can be targeted. With 3D ISO Machining, multiple bounding curves can now be used to allow different areas to be machined in one job. In addition, 3D Z-level Shape Finishing includes several innovative features to improve machining quality, including optimized sorting of toolpath, smooth overlap at boundary, free tool geometry and trim toolpath to stock.
hyperMILL® 2021.2 also has new functions that provide better feedback during CAM programming. Automatic Stock Display displays stock automatically for any machining job. Also, there is a new Preview of Selected Entities feature that highlights entities such as curves, faces, or points when a job is selected. And for component alignment at a touch of a button, a new Best Fit feature aligns the NC program automatically to the component position, eliminating manual alignment and optimizing the options offered by Virtual Machining. Learn more at www.openmind-tech.com
Latest from New Products
Inovatools Eckerle & Ertel
ATI Industrial Automation
ATI Industrial Automation’s patent-pending MC-50 manual tool changer.
Hamar Laser Instruments
The Hamar Laser Instruments L-703SP compact geometry, laser-based calibration system.
ECM PCB Stator Tech
An rotary electric motor with a PCB stator in place.
